Author Topic: Rohde & Schwarz RTO1024 Oscilloscope is broken, i need help  (Read 1109 times)
Offline myhobo
  • Country: cn
« on: April 04, 2019, 02:14:52 am »
I need the program file of this EEPRPOM, can anyone help me copy the program file of this chip, thank you
« Last Edit: December 09, 2019, 12:23:51 pm by myhobo »
Offline myhobo
  • Country: cn
Re: Rohde & Schwarz RTO1024 Oscilloscope is broken, i need help
« Reply #1 on: April 05, 2019, 02:39:24 pm »
who can help me
Offline myhobo
  • Country: cn
« Reply #2 on: April 05, 2019, 02:40:24 pm »
who have this oscilloscope serve manual
Offline perdrix
« Reply #3 on: April 06, 2019, 02:26:32 am »
You should be a little patient, chasing for replies after such a short time will not get you help faster.
Wait a day or two.
Offline myhobo
  • Country: cn
« Reply #4 on: April 07, 2019, 01:14:05 am »
thanks perdrix
Offline TRN
« Reply #5 on: May 02, 2019, 05:45:43 pm »
First run a self test, then run the internal alignment test, and upload the error log so the forum members can have a look at it.
My first guess is that the VarGain 50 and FixGain 50 errors from the self-alignment test probably indicate that there is an issue with the gain of the Variable gain amplifiers in the analog front-end.
To check this you should Inject an AC signal into the BNC inputs of channels 3 & 4 and measure the amplitude at the input of the ADC's from the same channels. Verifying these against the signal amplitudes of channels 1 & 2 should give you an idea if the variable gain amplifiers are suspect.
regards
Offline myhobo
  • Country: cn
« Reply #6 on: December 09, 2019, 12:20:45 pm »
My RTO1024 oscilloscope bios chip program is broken, the machine cannot start, can anyone help me copy the content of this chip, thank you
Offline myhobo
  • Country: cn
« Reply #7 on: December 09, 2019, 12:24:44 pm »
