Author Topic: Fluke 289 not quite sorted.  (Read 67812 times)
squadchannel and 2 Guests are viewing this topic.
Offline MihaiV
Re: Fluke 289 not quite sorted.
« Reply #200 on: December 27, 2021, 07:41:01 pm »
Hello,
Before scorching the MXS (again) to reflow it, I played a little with the TTL console at J5.
At power on it sends a "+"  followed by "Entry point: 0x00060040, address range: 0x00060000-0x003bef68".
Ctrl-C during power-up did not get me to RedBoot.
I pulled down E29 with 1k and that solved it.
Here it is:
 RedBoot(tm) bootstrap and debug environment [ROMRAM]
Non-certified release, version v2_0_74 - built 15:56:18, Sep 27 2007)
Platform: Fluke Clem (ARM9)
Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
Copyright (C) 2003, 2004, 2005, 2006, 2007 eCosCentric Limited
RAM: 0x00000000-0x007fb500, [0x0004dcb0-0x005d8500] available
FLASH: 0x10000000-0x107fffff, 63 x 0x20000 blocks, 4 x 0x8000 blocks
Next, I poked around the console, especially following the lines from frenky (post 59). My returns are the same, except that the app loads, clem.img.fs is ok.
RedBoot>fconfig -l
Run script at boot: false
Use BOOTP for network configuration: false
Gateway IP address: 0.0.0.0
Local IP address: 192.168.9.133
Local IP address mask: 255.255.0.0
Default server IP address: 192.168.100.100
Console baud rate: 115200
DNS server IP address: 0.0.0.0
Set eth0 network hardware address [MAC]: true
eth0 network hardware address [MAC]: 0x00:0x80:0x40:0x00:0x22:0x85
GDB connection port: 9000
Force console for special debug messages: false
Network debug at boot time: false
RedBoot>fis list
Name              FLASH addr  Mem addr    Length      Entry point
RedBoot           0x10000000  0x10000000  0x00040000  0x00000000
fs                0x10040000  0x00000000  0x007A0000  0xFFFFFFFF
FIS directory     0x107E0000  0x107E0000  0x0001F000  0x00000000
RedBoot config    0x107FF000  0x107FF000  0x00001000  0x00000000
RedBoot> fs info
Filesystems available:
devfs
jffs2
Devices available:
/dev/flash/
RedBoot>  fs list
fs: No filesystems mounted
RedBoot>  fs mount -d /dev/flash/ -t jffs2 /hmm1
fs mount: mount(/dev/flash/,/hmm1,jffs2) failed 2
RedBoot> fs mount -d /dev/flash/ -t devfs /hmm1
RedBoot> fs info
devfs
jffs2
Devices available:
/dev/flash/
Mounted filesystems:
            Device               Filesystem Mounted on
                     /dev/flash/      devfs /hmm1
RedBoot> fs list
fs list: no such directory /
RedBoot>  d -b 0x107FF000 -l 0x00001000
107FF000: 00 10 00 00 CE FA AD 0B  01 0C 01 00 62 6F 6F 74  |............boot|
107FF010: 5F 73 63 72 69 70 74 00  00 00 00 00 04 11 01 0C  |_script.........|
107FF020: 62 6F 6F 74 5F 73 63 72  69 70 74 5F 64 61 74 61  |boot_script_data|
107FF030: 00 62 6F 6F 74 5F 73 63  72 69 70 74 00 66 69 73  |.boot_script.fis|
107FF040: 20 75 6E 6C 6F 63 6B 20  66 73 0A 66 73 20 6D 6F  | unlock fs.fs mo|
107FF050: 75 6E 74 20 2D 64 20 2F  64 65 76 2F 66 6C 61 73  |unt -d /dev/flas|
107FF060: 68 2F 66 69 73 2F 66 73  20 2D 74 20 6A 66 66 73  |h/fis/fs -t jffs|
107FF070: 32 20 2F 0A 6C 6F 61 64  20 2D 6D 20 66 69 6C 65  |2 /.load -m file|
107FF080: 20 2F 73 79 73 74 65 6D  2F 61 70 70 73 2F 63 6C  | /system/apps/cl|
107FF090: 65 6D 2E 69 6D 67 0A 66  73 20 75 6D 6F 75 6E 74  |em.img.fs umount|
107FF0A0: 20 2F 0A 67 6F 20 2D 63  20 2D 6E 0A 0A 00 00 00  | /.go -c -n.....|
107FF0B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF0C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF0D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF0E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF0F0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF100: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF110: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF120: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF130: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF140: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF150: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF160: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF170: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF180: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF190: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF1A0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF1B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF1C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF1D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF1E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF1F0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF200: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF210: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF220: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF230: 00 00 00 00 00 00 00 00  00 00 00 00 00 02 14 01  |................|
107FF240: 0C 62 6F 6F 74 5F 73 63  72 69 70 74 5F 74 69 6D  |.boot_script_tim|
107FF250: 65 6F 75 74 00 62 6F 6F  74 5F 73 63 72 69 70 74  |eout.boot_script|
107FF260: 00 01 00 00 00 01 06 01  00 62 6F 6F 74 70 00 00  |.........bootp..|
107FF270: 00 00 00 05 14 00 06 62  6F 6F 74 70 5F 6D 79 5F  |.......bootp_my_|
107FF280: 67 61 74 65 77 61 79 5F  69 70 00 62 6F 6F 74 70  |gateway_ip.bootp|
107FF290: 00 00 00 00 00 05 0C 00  06 62 6F 6F 74 70 5F 6D  |.........bootp_m|
107FF2A0: 79 5F 69 70 00 62 6F 6F  74 70 00 C0 A8 09 85 05  |y_ip.bootp......|
107FF2B0: 11 00 06 62 6F 6F 74 70  5F 6D 79 5F 69 70 5F 6D  |...bootp_my_ip_m|
107FF2C0: 61 73 6B 00 62 6F 6F 74  70 00 FF FF 00 00 05 10  |ask.bootp.......|
107FF2D0: 01 00 62 6F 6F 74 70 5F  73 65 72 76 65 72 5F 69  |..bootp_server_i|
107FF2E0: 70 00 C0 A8 64 64 02 12  01 00 63 6F 6E 73 6F 6C  |p...dd....consol|
107FF2F0: 65 5F 62 61 75 64 5F 72  61 74 65 00 00 C2 01 00  |e_baud_rate.....|
107FF300: 05 07 01 00 64 6E 73 5F  69 70 00 00 00 00 00 01  |....dns_ip......|
107FF310: 09 01 00 65 74 68 30 5F  65 73 61 00 01 00 00 00  |...eth0_esa.....|
107FF320: 06 0E 01 09 65 74 68 30  5F 65 73 61 5F 64 61 74  |....eth0_esa_dat|
107FF330: 61 00 65 74 68 30 5F 65  73 61 00 00 80 40 00 22  |a.eth0_esa...@."|
107FF340: 85 00 00 02 09 01 00 67  64 62 5F 70 6F 72 74 00  |.......gdb_port.|
107FF350: 28 23 00 00 01 13 01 00  69 6E 66 6F 5F 63 6F 6E  |(#......info_con|
107FF360: 73 6F 6C 65 5F 66 6F 72  63 65 00 00 00 00 00 02  |sole_force......|
107FF370: 14 01 13 69 6E 66 6F 5F  63 6F 6E 73 6F 6C 65 5F  |...info_console_|
107FF380: 6E 75 6D 62 65 72 00 69  6E 66 6F 5F 63 6F 6E 73  |number.info_cons|
107FF390: 6F 6C 65 5F 66 6F 72 63  65 00 00 00 00 00 01 0A  |ole_force.......|
107FF3A0: 01 00 6E 65 74 5F 64 65  62 75 67 00 00 00 00 00  |..net_debug.....|
107FF3B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF3C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF3D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF3E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF3F0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF400: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF410: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF420: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF430: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF440: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF450: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF460: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF470: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF480: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF490: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF4A0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF4B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF4C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF4D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF4E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF4F0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF500: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF510: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF520: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF530: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF540: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF550: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF560: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF570: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF580: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF590: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF5A0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF5B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF5C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF5D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF5E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF5F0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF600: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF610: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF620: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF630: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF640: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF650: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF660: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF670: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF680: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF690: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF6A0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF6B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF6C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF6D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF6E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF6F0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF700: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF710: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF720: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF730: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF740: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF750: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF760: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF770: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF780: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF790: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF7A0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF7B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF7C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF7D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF7E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF7F0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF800: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF810: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF820: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF830: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF840: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF850: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF860: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF870: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF880: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF890: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF8A0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF8B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF8C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF8D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF8E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF8F0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF900: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF910: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF920: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF930: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF940: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF950: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF960: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF970: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF980: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF990: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF9A0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF9B0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF9C0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF9D0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF9E0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FF9F0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA00: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA10: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA20: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA30: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA40: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA50: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA60: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA70: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA80: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFA90: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFAA0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFAB0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFAC0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFAD0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFAE0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFAF0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB00: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB10: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB20: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB30: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB40: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB50: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB60: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB70: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB80: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFB90: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFBA0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFBB0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFBC0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFBD0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFBE0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFBF0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC00: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC10: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC20: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC30: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC40: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC50: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC60: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC70: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC80: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFC90: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFCA0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFCB0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFCC0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFCD0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFCE0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFCF0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD00: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD10: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD20: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD30: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD40: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD50: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD60: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD70: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD80: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFD90: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFDA0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFDB0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFDC0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFDD0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFDE0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFDF0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE00: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE10: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE20: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE30: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE40: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE50: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE60: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE70: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE80: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFE90: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFEA0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFEB0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFEC0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFED0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFEE0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFEF0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF00: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF10: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF20: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF30: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF40: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF50: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF60: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF70: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF80: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFF90: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFFA0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFFB0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFFC0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFFD0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFFE0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
107FFFF0: 00 00 00 00 00 00 00 00  AD DE AD DE C2 D7 ED EA  |................|
The script from RedBoot Config
fis unlock fs
fs mount -d /dev/flash/fis/fs -t jffs2 /
load -m file /system/apps/clem.img
fs umount /
go -c -n
runs with no errors and brings me to the same result, entry point...
Is there a way to check the RAM? I only found flash operation commands but nothing related to RAM.
Offline kjk24
« Reply #201 on: December 30, 2021, 06:49:39 am »
Hi MihaiV,
the ram is usable at redboot see older post,
there are some ram commands avail
like
w4   0x00221000   0xa2120200
mem32 0x8000000,1
J-Link>w4 0x221000,0x80000000
Writing 80000000 -> 00221000
J-Link>mem32 0x8000000,10
08000000 = FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
08000010 = FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
08000020 = FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
08000030 = FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
J-Link>w4 0x221000,0x80010000
Writing 80010000 -> 00221000
bootscript :
4. fconfig -l show config
5. fconfig -i
Initialize non-volatile configuration - continue (y/n)? y
Run script at boot: true
Boot script:
Enter script, terminate with empty line
>> fis unlock fs
>> fs umount /
>> go -c -n -w 10000
Boot script timeout (1000ms resolution): 10
Force console for special debug messages: true
Console number for special debug messages: 0
Update RedBoot non-volatile configuration - continue (y/n)? y
@ cristaux66
you need jtag to the msp and MSPFlasher, the hex file for it.
and flash it.
best regards
kai
I7 &
E4 1.19.8
The following users thanked this post: MihaiV
Offline MihaiV
« Reply #202 on: December 30, 2021, 08:41:17 pm »
Hello kjk24,
We are lucky enough to have a J-link Pro at work! Unfortunately I suck at programming, so I will certainly need more help on setup, commands and such.
I understand that I must install J-MEM and J-Flash from Segger.
I see a file at post 163, (MC9328MXS_1.jflash), with some "steps" inside it (various write and read commands) . Is it a script that runs RAM tests or just a configuration file?
I ran the boot script in redboot step by step and it runs without errors. It loads the clem.img, it mounts it and after the "go -c -n" it prints a "+" and "Entry point ..." and the green led turns off. I see something more at the "go" command, the -w and 10000 that is not in the boot script inside my meter. I'll try it again.
The meter is a 287/NUC (whatever NUC means).
My PCB is marked as REV 015, but there is also a sticker on the PCB with "287 R.020 AJ764496". So i guess it has REV 20 on it, as R277, R125 and R121 are populated (so assembled ModellA, ID0). Also, VR1, VR2, VR3, VR4 and other parts are not populated.
I'll get to the J-link after 5th January. Until then I'll read some more about the J-link tools and check the RAM lines with the scope. Play with hardware 'til i get to the software.
By the way, the Micron part marking decoder indicates that PW755 is for Micron MT45W2MW16BGB-701 IT, and it appears to fit the footprint (at least the VCC and VSS pins do). Is this the one? I saw in your photos a part number marked ISSI, but the photo was not clear enough to see hte code itself.
Thank you,
MihaiV.
Offline kjk24
« Reply #203 on: December 31, 2021, 09:20:08 am »
Hello kjk24,
Not sure what you mean, the bootscript execute and the device is booting without ram tests.
W is wait, see documentation for redboot.
+ is from the chip bootloader (press somthing and you are in....) after that redboot is loading....
i have pdfs i dont remamber exactly. i have parts left and a hole DMM without display to sell
MT45W2MW16BGB-708-WT-TR
MT45W4MW16BCGB-701-IT-Micron
Thank you,
MihaiV.
best regards
kai
I7 &
E4 1.19.8
Offline MihaiV
« Reply #204 on: December 31, 2021, 05:31:44 pm »
Hello kjk24,
I checked the fs_info.txt and I found the same things inside my DMM with few exceptions.
My clem.img has a different size (3594744). Yours has 3593752.
In my health directory are two files, one named SysHealthLog (size 35750) and a BackupSysHealthLog (size 4096). Yours has only the SysHealthLog (size 3933).
The contents of fs is listed below:
RedBoot> fis unlock fs
RedBoot> fs mount -d /dev/flash/fis/fs -t jffs2 /
RedBoot> fs list
   1 drwxr-xr-x  1 size      0 .
   1 drwxr-xr-x  1 size      0 ..
   4 drwxr-xr-x  1 size      0 tmp
   5 drwxr-xr-x  1 size      0 user
   3 drwxr-xr-x  1 size      0 system
   2 drwxr-xr-x  1 size      0 checkpoint
RedBoot> fs cd tmp
RedBoot> fs list
   4 drwxr-xr-x  1 size      0 .
RedBoot> fs cd ./
RedBoot> fs list
RedBoot> fs cd user
RedBoot> fs list
   5 drwxr-xr-x  1 size      0 .
  10 drwxr-xr-x  1 size      0 setup
  11 drwxr-xr-x  1 size      0 stored
   9 drwxr-xr-x  1 size      0 calibration
RedBoot> fs cd setup
RedBoot> fs list
  10 drwxr-xr-x  1 size      0 .
   5 drwxr-xr-x  1 size      0 ..
1051 -rwxr-xr-x  1 size    371 BackupSetupResetData
1052 -rwxr-xr-x  1 size     44 SetupNonResetData
1053 -rwxr-xr-x  1 size    371 SetupResetData
1050 -rwxr-xr-x  1 size     44 BackupSetupNonResetData
RedBoot> fs cd ..
RedBoot> fs list
RedBoot> fs cd stored
RedBoot> fs list
  11 drwxr-xr-x  1 size      0 .
  12 drwxr-xr-x  1 size      0 meas
  14 drwxr-xr-x  1 size      0 peak
  13 drwxr-xr-x  1 size      0 minmax
  15 drwxr-xr-x  1 size      0 recording
  16 drwxr-xr-x  1 size      0 records
RedBoot> fs cd ..
RedBoot> fs list
RedBoot> fs cd calibration
RedBoot> fs list
   9 drwxr-xr-x  1 size      0 .
  28 -rwxr-xr-x  1 size   1098 CalConstant
RedBoot> fs cd ./
RedBoot> fs list
RedBoot> fs cd ./ !!!!!!!! nu merge
RedBoot> fs list
RedBoot> fs cd system
RedBoot> fs list
   3 drwxr-xr-x  1 size      0 .
   6 drwxr-xr-x  1 size      0 apps
   7 drwxr-xr-x  1 size      0 health
RedBoot> fs cd apps
RedBoot> fs list
   6 drwxr-xr-x  1 size      0 .
   3 drwxr-xr-x  1 size      0 ..
   8 -rw-r--r--  1 size 3594744 clem.img // different size
RedBoot> fs cd ..
RedBoot> fs list
RedBoot> fs cd health
RedBoot> fs list
   7 drwxr-xr-x  1 size      0 .
 904 -rwxr-xr-x  1 size  35750 SysHealthLog // different size
  41 -rwxr-xr-x  1 size   4096 BackupSysHealthLog // new file
RedBoot> fs cd ./
RedBoot> fs list
RedBoot> fs cd checkpoint
RedBoot> fs list
   2 drwxr-xr-x  1 size      0 .
  40 -rwxr-xr-x  1 size      4 uid
  17 -rwxr-xr-x  1 size      4 sysFilesBytes
Next, I updated the bootscript with the one from the redboot info.txt file you attached.
I introduced the exact instructions, keeping the MAC address:
RedBoot> fconfig -i
Boot script:
>> fis unlock fs
>> fs umount /
>> go -c -n -w 10000
eth0 network hardware address [MAC]: 0x0E:0x00:0x00:0xEA:0x18:0xF0
RedBoot> reset
... Resetting.
And reset. Here is the output:
+Aborted RBINIT
No network interfaces found
== Executing boot script in 10.000 seconds - enter ^C to abort
RedBoot> load -m file /system/apps/clem.img
RedBoot> fs umount /
RedBoot> go -c -n -w 5
About to start execution at 0x00060040 - abort with ^C within 5 seconds
It start execution in 5s because I wanted to see what happens after: nothing different, the green led turns off and the same gray screen appears.
Here is what I don't understand (please correct where I am wrong):
- the clem.img is the application that manages everything and is stored in Flash.
- At boot, the script mounts the JFFS2 partition that contains the clem.img
- Next, we load the clem.img itself. This means it is now loaded in RAM, right?
- Next, the go command initiates execution.
Now about the the redboot_info.txt (also correct me where I am wrong):
- The " fis create fs -n -f 0x10040000 -l 0x007A0000 " command will create in FLASH a new file system, starting at address 0x10040000, with length 0x007A0000. The -n will not alter the flash contents, so there is no danger to overwrite important stuff, right?
- The next instructions load the newly created file system in RAM, starting at the lowest free RAM address and write the clem.img in RAM, correct?:
load fs -r -b %{FREEMEMLO} -m ymodem
fis unlock fs
fis create fs
load clem.img -r -b 0x00050000 -m ymodem
fs write -b 0x00050000 -l 0x003bd617 clem.img
RedBoot>fis list
- Next, we run "by hand" the boot script:
RedBoot config:
fis unlock fs
fs umount /
go -c -n -w 10000
- The "fis init" command appears to format the FLASH. Won't I loose the clem.img and everything in flash?
- The "copy files to device" commands at the end of the file appear to duplicate the clem.img and save it to BackupClem.img. Where do I get the "new" clem.img and how do I ulopad it? What exactly happens here?
copy file to device:
boot to redboot
fis unlock fs
fs cd /system/apps/
fs list
fs move clem.img BackupClem.img
RedBoot> fs list
 621 -rwxr-xr-x  1 size 3921431 clem.img
 596 -rwxr-xr-x  1 size 3922423 BackupClem.img
RedBoot> reset
Sorry for my lack of computer knowledge, they were overwritten long ago.
Thank you for your time and patience,
MihaiV.
Offline booyeah
  • Country: ie
« Reply #205 on: January 03, 2022, 10:27:34 pm »
For the clem.img:
https://www.fluke.com/en-ie/support/software-downloads/fluke-287-and-289-multimeter-firmware-update
The downloaded 287 update exe creates a folder containing clem_1_16.img.gz which contains the clem.img
Note it also says "Version 1.16 does not apply for units labeled 287/TPWS or 287/NUC." so might want to check which meter you have.
My 287, 289 and the downloaded clem.img are all version 1.6 so have a size of 3593752.
Not sure how you'd check which version you have, but as per kjk24s posts you could create a backup copy of the existing clem.img first.
Offline MihaiV
« Reply #206 on: January 04, 2022, 07:32:44 pm »
Damn  >:( ! It's a NUC!
I don't now what software version I have though. I'm only getting the redboot version, not the application version. I don't have even the DMM's serial number (or I'm looking in the wrong places).
I also do not have an IR189USB cable, but I found some homebrew ones here: https://www.eevblog.com/forum/buysellwanted/w-t-b-fluke-ir189-usb-usb-cable-280180-series/msg1436629/#msg1436629
I'll  try the transistor one first. I already have a FTDI USB-TTL converter and the rest is peanuts.
How can I check if the optical interface works? I guess it should respond to commands (such as ID) or be detected by the update software.
I doubt it would respond at QM  :D .
In case the optical path is not working, can a Jlink be used to replace the entire content of the flash with a copy from another (working) meter?
MihaiV.
Offline Arhigos
  • Country: gr
« Reply #207 on: January 06, 2022, 01:15:47 pm »
(Attachment Link)
MihaiV.
287/nuc is a special version of multimeter for french nuclear power plants and it has different firmware, different hardware and even different shield design. Even if you somehow upload flash from regular model 287 it will not work properly.
To check remote interface use 115200 Baud, no parity, 8 bits, 1 stop bit and it should respond to ID command with model and serial number. Viewforms software will also autodetect and autoconnect to the meter
« Last Edit: January 06, 2022, 01:22:05 pm by Arhigos »
Offline MihaiV
« Reply #208 on: January 08, 2022, 12:35:18 pm »
Hello Arhigos,
Indeed I got the dmm from a French seller.
It doesn't appear to have much shielding, in fact there is none at all, on the enclosure or PCB. I attached some photos with it.
As for the hardware, in the placed I looked I couldn't find differences from the meters in this thread. Perhaps they are more subtle or in other places. Could you please point out some of them? Where should I look?
I must mention that the meter was opened before it got to me. The screw heads on the input jacks were slightly damaged, like an unsuitably large screwdriver was used to tighten them. So someone played in there before.
I will return with the result on the optical path. I don't have the Fluke View Forms software, so I'll try it with a serial terminal.
Offline MihaiV
« Reply #209 on: January 08, 2022, 12:37:24 pm »
And the next attachments.
Offline MihaiV
« Reply #210 on: January 08, 2022, 12:39:04 pm »
Offline Arhigos
  • Country: gr
« Reply #211 on: January 09, 2022, 12:26:36 pm »
Board looks different from other nuc that i saw, but could be just a different revision. Or you could have a board from regular fluke 287 swapped inside the nuc case. The one i saw had a big resistors under resistor network and shield was different so that modified PCB can fit inside the meter.
Also, maybe i missing that, but what was the current draw when meter turns on? Also, it seems like you missing beeper for some reason. Did you just removed beeper?
« Last Edit: January 09, 2022, 12:39:29 pm by Arhigos »
Offline MihaiV
« Reply #212 on: January 10, 2022, 04:43:09 pm »
Hello,
Thanks for the details. Maybe only the LCD bezel with the NUC inscription is changed.
I removed the beeper to be able to apply heat from under the MXS. Being plastic, I figured it could get some damage.
The back-up capacitor had a trace of corrosion so I removed it before anything else.
F1 fuse was missing from the beginning. Only F2 was installed.
I also changed the MXS crystal, as the original one was not oscillating at all. But the boot splash screen displayed without it. I used a low capacitance probe for it. With the new one it is strong and stable.
The current draw is each phase is:
- in sleep (9V applied, meter off): 36uA;
- during boot (while green led is on): 44mA
- after boot (led off, screen gray): 15.2mA
Boot appears to be divided in two: for ~1s it draws 7mA, then for 0.5s it draws 10mA and after this the led turns on and it jumps to 44mA.
After the power on button is pressed the beeper makes a very short beep (barely audible, 10us) and the same thing just before the screen goes gray.
I must mention that the 5V rail for the analog side is not enabled, the MSP keeps the regulator disabled, so those 15mA are only for the digital side.
Offline Arhigos
  • Country: gr
« Reply #213 on: January 14, 2022, 03:41:55 pm »
Yeah that sounds little bit low. It should be somewhere over 20mA.
Have you checked l1 and l2 inductors?
Offline MihaiV
« Reply #214 on: January 15, 2022, 06:52:58 pm »
L1 and L2 are ok, and so are all regulators. I have 1.805V at TP18, 2.950 at E35, 21.174V at E41 and 3.055 at TP32.
U17 is also OK, meaning it provides 5V for a moment, but is quickly disabled by the MSP430.
Yesterday I breadboarded and validated a IR serial link using a FTDI and I'm building it on proto-board.
I configured the link in loopback (IR led looking straight at the phototransistor) and I started the FlukeView. With a port sniffer I observed several identifications commands sent by Forms: ID, ~ID, *IDN?  with 115200 and 9600 baud.
Just to make sure, the IR receiver is CR13, the component with the dark package, right?
Offline MihaiV
« Reply #215 on: February 12, 2022, 05:10:59 pm »
Hello,
I made a optical USB adapter (as in reply nr. 2 here: https://www.eevblog.com/forum/buysellwanted/w-t-b-fluke-ir189-usb-usb-cable-280180-series/msg1436629/#msg1436629). I built the one without comparators and tested it in optical loopback mode at 115200 baud.
Stuck it in the meter's "eyes" and no response. I traced the signal through the photodiode, R150 to U23 (an OPA364). Also tried it with TX inverted, but in both cases there was no response on the IR led. The signal looks good, even at 57600 max baud coming from the FlukeView forms software. Interesting fact that the negative supply of U23 comes through a diode in CR12. Perhaps to keep the inputs/output in proper operating range (even though it is RRIO).
I have one more lead with the Jlink, to check RAM operation as kjk24 instructed above, but after that I'm out of ideas.
Offline Arhigos
  • Country: gr
« Reply #216 on: February 17, 2022, 05:52:03 am »
At this point i think you probably have bad bga flash chip or corrupted flash, or dead cpu.
You will not get ir communication until arm processor is fully boot up.  You have 2 ethernet connectors for that kind of debug, but I don't know how to use them.
Offline maximalcho
  • Country: bg
« Reply #217 on: February 18, 2022, 08:57:05 am »
Hi MihaiV
did you try to connect fluke with J-Link because I fail. I try to connect it according to J-Link pinout without success.
I have another jtag programmer  with which I manage to connect to MXS but I do not have access to flash memory or maybe flash is dead.
Offline MihaiV
« Reply #218 on: February 25, 2022, 07:18:45 pm »
Hi maximalcho,
I was away for the week so I didn't have a chance to try it.
Will try something this weekend and posts results (if any) here.
Offline maximalcho
  • Country: bg
« Reply #219 on: March 11, 2022, 06:41:23 am »
i fixed my multimeter.I changed flash ic and program with one of dumps from here.The multimeter is now fully functional.
The following users thanked this post: kjk24
Offline MihaiV
« Reply #220 on: March 11, 2022, 07:50:05 pm »
Congratulations, hope you enjoy the meter for a long time!
May I ask what flash contents and what component part number you used? You used the Jlink or another programmer?
Thanks,
Mihai V.
Offline maximalcho
  • Country: bg
« Reply #221 on: March 12, 2022, 06:51:59 am »
First I used dump from kjk24 (thank you kjk24) reply #153  and program last dump from archive (_ok_0x10000000-0x101E0010).Multimeter start but not fully load (my multimeter was fully dead) then i program dump from AnJu (Спасибо AnJu ) reply #83 and thadaaa the multimeter came back to life.And because the АnJu dump is from 287 and mine is 289, I made an official update for 289 via the Ir port just in case.I used the jlink programmer and I ordered the flash ic from digikey https://www.digikey.bg/en/products/detail/alliance-memory-inc/PC28F640P30TF65A/13543373.
PS:To make connection with Jlink LCD must be connected ! Оtherwise mxs is in sleep mode and no connection can be made.
« Last Edit: March 12, 2022, 06:59:06 am by maximalcho »
Offline maximalcho
  • Country: bg
« Reply #222 on: March 12, 2022, 07:14:26 am »
One more thing.First when i program dump from kjk24 my multimeter stuck at the same screen like yours from reply #166.You can try to program with jlink a dump from AnJu and if you are lucky the multimeter will come to life.
Offline MihaiV
« Reply #223 on: March 12, 2022, 05:27:49 pm »
Hello,
Thank you!
I tried today something. Here goes:
I managed to connect to the target using Jflash and the configuration file from post #163, from kaiser. The log output is:
Connecting ...
 - Connecting via USB to probe/ programmer device 0
 - Probe/ Programmer firmware: J-Link Pro V4 compiled Sep 24 2021 16:41:59
 - Device "ARM7" selected.
 - Target interface speed: 30 kHz (Fixed)
 - VTarget = 3.071V
 - TotalIRLen = 4, IRPrint = 0x01
 - JTAG chain detection found 1 devices:
 -  #0 Id: 0x1092001D, IRLen: 04, ARM920T Core
 - Identified core does not match configuration. (Found: ARM9, Configured: ARM7)
 - CP15.0.0: 0x41129200: ARM, Architecture 4T
 - CP15.0.1: 0x0D172172: ICache: 16kB (64*8*32), DCache: 16kB (64*8*32)
 - Cache type: Separate, Write-back, Format A
 - Executing init sequence ...
  - Initialized successfully
 - Adaptive clocking not supported for selected CPU core. Only supported for -S cores.
 - Auto JTAG speed: 8000 kHz
 - Target interface speed: 8000 kHz (Auto)
 - Found 1 JTAG device. Core ID: 0x1092001D (None)
 - Connected successfully
Next, I tried to read the flash contents: Target>Manual Programming>Read back>Entire chip.
The response is:
Reading selected sectors ...
 - 67 of 67 sectors selected, 1 range, 0x10000000 - 0x107FFFFF
 - Start of determining flash info (Bank 0 @ 0x10000000)
 - End of determining flash info
 - Flash bank info:
 - 63 * 128 KB @ 0x10000000
 - 4 * 32 KB @ 0x107E0000
 - Start of preparing flash programming
 - ERROR: Failed to read back RAMCode for verification.
 - ERROR: Failed to prepare for programming.
Failed to download RAMCode!
 - End of preparing flash programming
 - Start of restoring
 - End of restoring
 - ERROR: Failed to read back target memory
Disconnecting ...
 - Disconnected
And a warning message (photo 3).
1437346-0
Next, I tried to connect using the command line (JLink commander). Connected ok and saved the entire contents of the flash using savebin command, starting from address 0x10000000.
And it worked, i have a copy of the flash contents, from 0x10000000 to 0x107FFFFF. This means that the flash chip and the connections to it are ok.
I attached it below.
I checked its contents with the dump from AnJu, as indicated by maximalcho (Thansks!). They are very similar.
I tried to check the RAM, as indicated by kjk24 in post 201, using the w4 and mem32 commands.
However, there is no response. I tried with single bytes and I do not get an output. See photo 2.
1437352-1
Reading works using the mem8 command on flash (see photo 1). The output fits with the contents i got using the savebin command.
1437358-2
Does it mean i have a bad ram, or with bad connections?
Is itpossible to brick the meter if I upload the contents from AnJu ("2.fs 0x10040000.bin" starting from address 0x10040000 and "3.FIS directory 0x107E0000.bin" from address 0x107E0000) and having a bad ram?
Especially if using "Use target ram" option enabled?
Thank you,
MihaiV.
Offline maximalcho
  • Country: bg
« Reply #224 on: March 12, 2022, 07:15:56 pm »
Once you have a full dump on your flash chip I don't think you can brick the multimeter.If the ram is really damaged when trying to program flash it will probably give an error in the worst case the device will stop but when you change the ram you will be able to restore it.If you try to program flash and it doesn't work you may have tried to reball the memory or just to reflow.Try to change the core type in the configuration file because it is not correct at the moment, but keep in mind that when you change it you have to reconfigure the type of flash memory and its address.
