Author Topic: fluke 30 clamp on amp meter wiring from lead board (probe board) to main board  (Read 2325 times)
Offline recountrymanTopic starter
Hello. I have a fluke 30 that had the lead jack pulled from the board and managed to make another one (used guide from modemhead..thanks by the way) but to make it easier I removed the 3 wire (hot, ground and common...a red , black and green wire)I had pics where they go go but due to smart phone dying I lost the pics.Anyone have one they can post a pic of?or can tell by the pics included where they go? I'm pretty sure where the hot wire goes but other 2 I have a 50/50 chance of getting it right and I'd rather not blow even though got it on the cheap.I'm a mechanical guy but will cross over to the wild side every now and then !thanks!
I circled with color where I "think" they go
« Last Edit: July 25, 2014, 12:08:19 am by recountryman »
Never mind I was correct and it now works great!
Offline miguelvp
I'm glad you figure it out, did search over the interwebs and I couldn't find a single image from the inside of the fluke 30.
I guess no one in here owns one either.
lol..I spent hours on google trying to find a image with no luck.Figured well try it like I thought and just ohm something out with the leads ans see what happens. Works great for just about 22 dollars given for it.
Offline retiredcaps
Same here.
Offline dardosordi
  • Country: ar
Hi recountryman,
I know this thread is very old but in the chance you or somebody else could post pictures of the wiring for the Fluke 32/32 on the main board.
I have one of each with all wires cut at board level, and trying to repair.
Thanks!
