Well, with a poke around I found a bunch of out of spec resistors in my unit and a busted Zener on the Aux PSU board. It's the precision CR6 6.3V one. I'll replace it with a standard zener for testing then swap to a 1N829A once it's working.
I think I'll rip out the carbon composite resistors and replace them all with metal film resistors (I can get 1% tolerance, 50ppm for a good price).
The resistance checks in the service manual at the start of the troubleshooting section indicate there is a problem with the Aux PSU board, so replacing these bits might just get it working..
