Its been a somewhat disappointing day.
-Installed new bridge for the relay PSU on pre regulator board
-Installed Q4, Q6, and Q8 on the amp board
-Installed new LEDs for the decimals
I was hoping with the relay PSU now functional and the missing transistors installed in the amp board I would get some sign of life from this thing, but no. Completely the same behavior when the unit is turned to "operate." I get 1.22v ish no matter the range or readout setting. The new LEDs work great so at least thats something
One thing I know is bad and has not been replaced is Q2 on the current limiter board. It has low hFE so figured it may not have a large effect on the function of the overall unit (correct, incorrect?).
Before cleaning the bench for the day I took voltage readings per 4.16 in the manual. Hoping someone may see something I dont/cant. I do see collector Q8 on the reference supply board is very high. Hoping that is not too ominous. I appreciate all the responses so far, hoping someone has some idea where I should go next.
Oh. On thing I have noticed is a intermittent buzzing sound (60hz maybe) from the HV mother board area. It comes and goes, but I have not isolated it to a specific component or to see if a specific relay energizes when it happens (dont want to stick my ears too close!) . Does not appear to be coming from the transformer.
I am absolutely determined to get this thing going.
Aux Power BoardPin 10 24.9v
Pin 9 -14.86v
Current LimiterPin 1 -35v
Pin 3 37.4v
Range Calsense to red test point 15.06v
Reference Supply
Collector Q1
45v (Should be 26-35v) Maybe l need to look at R19 or further up?
Rear Bulkhead Resistor Yellow lead 748v
Series PassCollector Q8 137.5v
