Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
fluke 3330B fault current output
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: fluke 3330B fault current output (Read 936 times)
NRP_SANTOS
Newbie
Country:
on:
December 07, 2021, 02:33:45 pm »
Hello friends, I'm looking for help repairing my fluke 3330b.
his problem is in currents above 3ma. Whichever scale is selected, it always maintains 6ma of output.
Best regards
nrp_santos
Logged
alm
Super Contributor
Country:
Re: fluke 3330B fault current output
Reply #1 on:
December 08, 2021, 12:35:18 pm »
Is it working below 3 mA? Does it jump right to 6 mA as soon as you set the current above 3 mA?
I haven't studied the schematic, but sounds like it might be a bad transistor to me. Although I would also check all voltage rails for ripple (bad caps).
Be aware there are lethal voltages inside, so be very careful operating it with the covers off.
Logged
Linux-GPIB packages for current Ubuntu versions
NRP_SANTOS
NRP_SANTOS
Newbie
Country:
Reply #2 on:
December 09, 2021, 09:44:58 am »
hello Alm,
I appreciate your availability.
It works below 3ma.
above the 3ma range it always maintains the 6ma output value.
best regards,
nrp_santos
Logged
Dr. Frank
Super Contributor
Country:
Reply #3 on:
December 09, 2021, 03:37:37 pm »
Hello,
does this error occur only in constant current mode, or also in constant voltage mode?
Frank
Logged
NRP_SANTOS
NRP_SANTOS
Newbie
Country:
Reply #4 on:
December 10, 2021, 09:43:33 am »
Hello Frank,
The problem only occurs in current.
When I select above 3ma.
the signal measured oscilloscope the input and output of the PCBs (A4A2 chopper amp., A4A3 differecial amp., and A4A4 series pass drive) occurs a 100hz oscillation.
NRP_SANTOS
Last Edit: December 10, 2021, 10:03:58 am by NRP_SANTOS
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
