Today my Fluke 337 had a power failure, batteries was dead but one of them was leaking a little bit, I cleaned it but it begins to beep and zero button did not work. I open it and there was some residual of the alkaline solution so I clean it up using some vinegar and isopropyl alcohol, and all begins to work almost perfectly, but there was some random beeping so I open again a couple of times UNTIL negative wire was cutter because the movement and some corrosion. I try to clean the soldering to reinstall the wire but this board has a
sleeved hole and that bloody wire tip was really hard to remove so I make a big mistake by pulling it out and the sleeve went out. I use a little piece of sandpaper to clean the copper around the hole and I was able to solder the wire, unfortunately, the Fluke 337 did not wake up again, I saw that the board is a multilayered one, so likely there is a lost connection inside. I was thanking to use an external wire to connect this point to where the wire is supposed to go, but I have no diagram. Since I was moving a lot the board, the positive wire got cut also but, leason lernt, y solder a new wire to the other side of the board. I could test that there was voltage present on the board when I installed the battery, so I don't really know if there are a missing o wrong connection or I kill my beloved meter. Any chance of help from you guys?
