did you solve this ?`
DS4, DS5, DS6, DS7 are 24V bulbs in the manual
but many units allready have LED in the 3 range indicators, like mine had
a normal 5mm LED will fit fine, just add 3k6 series resistor to a 202x age LED, and you see plenty of light..
i changed the 3 range dots to green, seems more logical to me.
the on-indicator is more likely bulbs, the hole in the metal tube fitted back side is impossible to remove, please dont try,
but here a 3mm led fit fine, again add 3k6 and a new age 3mm red led, here you cant change the color due to the colored transparent difuser
just let the 240 R series resistors for the bulbs sit where they are,
this way you modify as little as possible.
by the way : genius design with series resistors for bulbs, peak currents will be much less,
and bulb lifetime will be long.
