I have a Fluke 375 which is showing a large offset in the DC current mode without any wire or current (see image). The photo was taken while the meter was on a metal chair, but the negative reading doesn't change much if I move it around. I just received this meter so I'm not familiar with how it should normally operate.
Turning it off and on has no effect. The batteries in the meter measure fine. The zero button does nothing when I press it except chirp. The DC V and Ohms mode seem to work correctly. If I do put a DC current (say 1 A), the reading does change to reflect the current, so the meter is detecting a change (the reading changes by 1A). Is this a case of user error and there's a simple way to zero it out, or does it need to be re-calibrated, or is it broken and needs to be fixed?
Thanks for any suggestions.
