Electronics => Repair => Topic started by: Blynski on March 17, 2023, 07:24:16 pm
I am trying to fix my dad's Fluke 52 II and it appears to have multiple issues. Firstly, half of the header contacts had broken solder joins which I repaired. Secondly, it appears to have some damage and a missing passive component (probably a capacitor based on how it is acting). Attached is a picture I found of a good board with the missing component circled. Does anyone know the correct value of this component so I can order one and replace it (or someone with a schematic)?
The colour is reminiscent of a precision resistor. What resistance do you measure for the "2742" part and for the other unmarked part?
Thanks for the hint on it being a resistor. I’ll take some measurements tomorrow and report back.
Assuming you are correct I would still need someone with a good board or a schematic to help me out on the needed value.
The Linear part is a dual precision reference:
https://www.analog.com/media/en/technical-documentation/data-sheets/1034fe.pdf (https://www.analog.com/media/en/technical-documentation/data-sheets/1034fe.pdf)
That would lend support to the precision resistor idea.
Based on taking measurements on my board, I would agree that they are in fact resistors. Picture attached of the measured values. Essentially two 27.4k ohm and one 5k ohm resistor. So at least I know I'm looking for a precision resistor, but still need the correct value...
Just in case you don't have it, here is the service manual (but no circuits):
https://elektrotanya.com/fluke_51_52_53_54_series_ii_thermometer.pdf/download.html#dl (https://elektrotanya.com/fluke_51_52_53_54_series_ii_thermometer.pdf/download.html#dl)
Your board is the "isothermal PCA". I suspect it provides cold junction compensation for the thermocouple.
Ah I fixed mine after dropping it, I was very confused.
YOu see, that board has pins on it that are SMD! I thought they were through hole and figured there is no way that could break.
