Hi TonyG,
this failure principally can originate everywhere in the feedback loop.
Most probable is A7, HV-amplifier, the switching which determines 120V or 12V output range, as one hears relays clicking. These may be K1, K2. Read manual page 3-12, the last sentence, maybe this pin 29 shows erratic logic signals.
Does the output produce short pulses >> 10V in your current setting?
So what happens, if you switch to 120V range?
MSD frequency switch is the most significant decade, i.e. set to 0.1000 kHz, as you have done in your video.
I do not understand, why the front panel selector should not be active, even if the A10 is sitting on an extender board.
Good luck
Frank
