veedub565Upload to
my FTP server, I'll give you web-page with all links automatically. I still have some 180GB on storage available, should be enough
I meant to make a huge article about all 5700-related shenanigans (and photos, I have lot of gigabytes of photos of all different 5700/5720 and even 5730 variants), but easier to say than done.
That's useful to know, so looks like all of them came with the rear terminals, but only wired up as an option.
Not all of them, but most. And yes, you could order rear terminal option which means Fluke would disconnect front terminal cable and route it to rear instead. There is little different guarding as well in that configuration. The procedure is briefly outlined in SM, as user can do that swap too.
Yes, when I replaced resistors I went for bigger size instead of matching BOM to the letter. E.g. in many cases I've replaced 1/4 or 1/2W resistor with 2W or so, given other specs match or exceed. Also I liked to use MF resistors instead of thin/thick film, where possible, except high power resistors.
