You guessed it, I recently got a used dual laser Fluke 62 MAX+ infrared thermometer on the cheap to keep my single laser Fluke 62 MAX company,
and two meters are always the way to go to verify readings and operation
It had battery leakage from the single AA fitted, brown goo stuck on everywhere and suspect has gone inside too
The meter works perfect but I want to get in there asap and check and or clean up
I got as far as removing all the battery compartment 'miniature' screws (obvious and hidden.. and stubborn) but the meter body half will not lift off completely (stops halfway past the battery section)
and I don't want to force it like you would say a Fluke 114 / 117 series multimeter which sort of 'crack' open at the top without actually breaking anything
Is there a trick to it, or designed that way so user can't stuff up the calibrated innards and laser alignment thingies?
This is the first Fluke I haven't been able to get into
Any suggestions or 'leave it be' recommendations are appreciated
