Author Topic: Sony HT-CT290 independent subwoofer wont power on  (Read 1604 times)
Offline Im_TeslaTopic starter
  • Country: in
« on: October 28, 2020, 03:50:37 pm »
I've a 15 month old sony soundbar with independent subwoofer. The subwoofer wont turn on but the soundbar works fine. I've taken apart and did some measurements. Power supply board is producing 18.5V, I think main board has some problems. Can anyone help me what's wrong with the sub unit?
I've attached the measurements.
Second pic is of a component (4WHOVJ20865) which has 18.5V as input but output is 0V. Maybe this component is broken? Can anyone tell me exactly what is this 6 legged component?
https://pasteboard.co/JxKzHXC.jpg
https://pasteboard.co/JxKBmft.jpg
Offline akimpowerscr
Re: Sony HT-CT290 independent subwoofer wont power on
« Reply #1 on: October 28, 2020, 06:32:00 pm »
Always start with the simplest:
have you checked if the coil of your subwoofer speaker is not interrupted?
If not:
https://fr.ifixit.com/R%C3%A9ponses/Afficher/615901/Subwoofer+on+Sony+HT-CT290+sound+bar+not+working
« Last Edit: October 28, 2020, 06:48:24 pm by akimpowerscr »
  • Country: in
« Reply #2 on: October 29, 2020, 01:48:07 am »
Thanks a lot for the reply.
I've checked the sub speaker coil is good.
I've gone through the linked post and found that the Ti buck regulator is working fine and producing 3.27V. I think problem is something else.
See my 1st picture, I've mentioned the region that has no voltage. What could be causing that?
« Reply #3 on: October 29, 2020, 09:15:48 am »
To continue the search for faults, it would be necessary to have the service manual.
Unfortunately, I couldn't find it on the internet.
Maybe you will have more chances than me?
Offline andy3055
« Reply #4 on: October 30, 2020, 07:17:48 pm »
This site seems to have it but one has to make an account there to see the high res files.
https://servicemanuals.us/sony/audio/ht-ct370.html
