I've noticed remains of plastic film on mounted SMD trim caps before, the Murata datasheet for yours says it's a protective coating for bath soldering .
If there's no easy way to peel it and it's not designed to shrivel away to the edges when heated just pierce through it.
Is the voltage rating on that trimmer sufficient for the application?
