Author Topic: Fluke 760A Meter Calibrator Repair  (Read 1691 times)
Offline psykokTopic starter
« on: February 15, 2021, 04:26:51 pm »
Today I received my new lab encore
The package was well done and pain to open
On the device in the workshop, I could realise how big it is:
Cosmetic  condition is not great but apart  from missing screws and on missing button, it looks ok to me.
« Last Edit: February 15, 2021, 04:30:22 pm by psykok »
The following users thanked this post: capt bullshot, Kosmic
Re: Fluke 760A Meter Calibrator Repair
« Reply #1 on: February 15, 2021, 04:31:46 pm »
The next challenge would be to find an adequate power cord
« Last Edit: February 15, 2021, 04:33:32 pm by psykok »
Offline capt bullshot
« Reply #2 on: February 16, 2021, 09:09:23 am »
Nice haul ;)
Looking forward to see more repair / teardown.
« Reply #3 on: February 16, 2021, 12:41:03 pm »
Let's go for the teardown.
The outside condition is not very good but inside everything  looks good and almost clean (surprisely no dust)
First the upper part of the instrument
A look under the protection cover
Calibration board
The null detector board
AC converter
15v psu, assembly date is apparently in 75 ... was not even  born :)
« Last Edit: February 16, 2021, 12:51:12 pm by psykok »
« Reply #4 on: February 16, 2021, 01:02:20 pm »
If the two transformers  are huge, the caps too
Offline coromonadalix
« Reply #5 on: February 16, 2021, 03:30:20 pm »
be careful   the clear tubings on the pcb's  hide / protect wire wounded precision resistors
seems heavy as a tank,  sadly it seems to have been shaken a bit on the rear panel ??
« Reply #6 on: February 18, 2021, 06:50:58 am »
Indeed heavy as a tank but not armored like one.
The case is made of thin aluminium panels.
Fortunately this materiel is easy to bend and I was able to fix the back panel.
I Also replaced the power connector with a more traditional  one. This modification is completely reversible because the new connector is just fitting in the mounting holes of the previous one.
One the back panel in place, it doesn’t  look too bad, maybe  just missing a new paint.
Next job is fixing the wiring issues on the front command.
« Last Edit: February 18, 2021, 06:58:32 am by psykok »
