Fluke 87 have capacitance but not high values, first series was around 5 uf up to the 87 serie V who goes at 10,000 uf
But it is not an true capacitance meter with esr etc ...
And the most annoying functions "87V" are they start in AC mode you have to toggle it in DC a big no no for me.
Used and working Fluke 187 189 are selling pretty high 200-250$ usd range they go up to 50,000 uf, and they are 50,000 counts displays
For an serie 87, goes for the 87 (no roman letters means the first serie) or the serie 87 III (serie 3) at 20,000 count display it will be good enough for you.
The 87 IV is like an fluke 187, but i heard they had some ranges lags problems
The 187 had not this problem ?
You have Brymen, Fluke, Agilent, old Wavetek or Beckman Industrial ... any good reputable brands. Skip low end Uni-T meters, i think they are somewhat good starting with the UT-131 UT-181 ??
Personally, i avoid any oled based display meters.
Take you time to find an good reputation used clean meter and add an Deer De-5000 in your collection.
