Author Topic: help me find ob5284cp pwm ic or equivalent  (Read 103154 times)
Offline 800908Topic starter
  • Country: ir
« on: December 06, 2020, 06:30:11 am »
hi
this ic is belongs to TV power supply and I can not find datasheet for it.
the part number on is ob5284cp.
pin 4 is ground and pin 7 is Vcc.
it controls 7 Amper mosfet.
I am looking for common pwm that can be found easily.
thanks.
Offline amyk
Re: help me find ob5284cp pwm ic or equivalent
« Reply #1 on: December 06, 2020, 07:11:37 am »
Pin 7, are you sure?
OB5269 looks similar:
http://www.on-bright.com/cn/english/products_Ultra_low.htm
But you could try asking Onbright about the OB5284 yourself... they might even be willing to send you a sample!
The following users thanked this post: 800908
  • Country: ir
« Reply #2 on: December 06, 2020, 07:21:08 am »
as you can see in this picture after I took off the bad components pin 7 is connected to positive of caps. so it should be Vcc I think.
« Last Edit: December 06, 2020, 07:22:43 am by 800908 »
Offline picburner
« Reply #3 on: December 06, 2020, 07:42:04 am »
The pin connected to positive of cap is 6, pin 7 is not connected.
  • Country: ir
« Reply #4 on: December 06, 2020, 08:31:31 am »
oooh. I am so sorry. I am counting the top pins from left!
so are you sure that ob5269cp is the equivalent because if I order this I have to wait a week.
Offline amyk
« Reply #5 on: December 07, 2020, 12:31:58 am »
No, I am saying it look similar in pinout, but other specifications could be (very) different.
  • Country: ir
« Reply #6 on: December 07, 2020, 05:45:47 am »
OK. thanks.
the Onbright peoples didn't answer my email yet!
  • Country: ir
« Reply #7 on: December 07, 2020, 06:17:13 am »
sorry to bother you again.
on that picture the value of big resistor should be less than one ohm but two apps I use on my phone show different.
they say 24.9 ohm.
is it right?
Offline picburner
« Reply #8 on: December 07, 2020, 08:35:06 am »
Most likely it is a fusible resistor.
0.24 ohm, 5%. The purple violet color should indicate the tripping time as fuse.
« Last Edit: December 07, 2020, 10:51:13 am by picburner »
  • Country: ir
« Reply #9 on: December 17, 2020, 09:17:51 pm »
hi
today finally the ob5284cp ob5269cp arrived and it's working.
thanks for helping me.
« Last Edit: December 18, 2020, 08:28:54 am by 800908 »
The following users thanked this post: amyk
Offline amyk
« Reply #10 on: December 17, 2020, 10:19:54 pm »
So OnBright actually sent you a sample of ob5284, or did you buy one from them? :o
  • Country: ir
« Reply #11 on: December 18, 2020, 06:19:37 am »
No. Onbright not even answer my two emails.
i find it on local website.
  • Country: ir
« Reply #12 on: December 18, 2020, 08:34:29 am »
sorry by mistake I said ob5284cp arrived but actually I ordered ob5269cp from local website and I put it on the board and it working fine.
