Thanks ModemHead. I really appreciate your interest in helping with this. I did start with replacing ALL the transistors in this section (the smd componenents Q905,907,908 & 909 are the worst as they are miniscule but that seemed to go OK with the aid of
Chipquik). I also replaced Q904A (2N3906) and of course Q903 & Q906.
I'll now have to buy another Q903/906 pair before I continue as I suspect one or both are fried again (I have plenty of the SMD MMBT3904LT1G and 2N3096 left to swap out). In the meantime I can however, as you suggest, check the waveform on my scope (The TTL output is good but I guess that doesn't prove anything).
The components I replaced (i.e all the transistors) was on the advice of
Instek (it was their annotation on the image I included with my opening post). I do wonder though whether the 2 diodes D906 & D907 which seem to connect the Base and Emitter of Q903 & Q906, could be faulty?? What type of diodes do you think would be used here (eg a switching diode such as RLS4148) ?
EDIT: All waveforms (sine, Square & Triangle at different frequencies) are good at the base of Q909 , so the DAC is good
Once again thanks for your help.
Regards
Erik
