Hello:
After years of use, the slide switch to my Fluke 8060A fell apart today, the plastic tab broke off from the body that’s soldered to the main board.
The service manual description is “SPD Slide Switch”, which tells nothing about the voltage or current requirements. Also the side of the tab has to be small enough for the green switch cover.
Does anybody have a part number for this so I could order it from Mouse/Digikey?
Thanks.
