I understand what your open circuit voltages are. Those are determined by analog switches within U4 in conjunction with the various elements of Z1. Z1 is also used in a different way to divide the input for the voltage ranges. So if you have tested ALL your voltage ranges, mV to 1000V, and they all work, Z1 is good and your ohms problem would appear to be within U4. The usual disclaimers apply, like I might be wrong, strange things happen, we don't have the exact schematic, this advice is worth every penny you paid for it, etc.
