Electronics => Repair => Topic started by: newbie666 on March 02, 2018, 07:43:24 am
My fluke started loosing some segments on the display, is it a known issue? Any ideas if there's a fix doable by oneself?
Best regards
Afik this is a known occurrence.
Lots of info on YouTube, but this is the first one I saw.
https://youtu.be/6RBug_9Y47s
Sent from my SM-N950F using Tapatalk
Same result, but different approach.
Not sure which is the better / correct option.
https://youtu.be/ejvfzfGHz0c
If you plan to clean the circuit board pads which contact the elastomers - be extremely careful in removing the "top shield" with the little clip things that hold it to the board. The little clips break real easy. If this happens, it's not a deal-breaker, but better to be careful.
Yes, known issue. Easily fixed. See
http://mrmodemhead.com/blog/fluke-8x-faded-lcd/ (http://mrmodemhead.com/blog/fluke-8x-faded-lcd/)
Thanks a lot for all the replies. I'll attempt a fix next weekend!
