Hello, my first post!
I have purchased a used, damaged Fluke 867 Multimeter (which I intend to fix), and it has no charging adapter and those of you who own one of these will know that they, the instrument themselves and their adapters, are relatively rare. To make matters worse, the adapter uses a 'proprietary' barrel connector. (Also used by the 863, 865, 867B)
The adapters themselves sell for as much as $300, though I have found an aftermarket knock off for ~$65USD, I am considering building one, which will involve sourcing the barrel and casting the plastic end using a mold.
To that end, might there be some kind soul who owns one of these units that could measure the connector and provide me with the data I need to make my own?
To facilitate, I have drawn up the diagram below, and am looking for the following measurements;
A: Plastic Barrel Length :
B: Metal Barrel Length :
C: Plastic Barrel Diameter :
D: Metal Barrel Diameter :
E: Tip Hole Diameter :
Thanks in advance to anyone who is willing to take this on for me. I did search the forum, no luck.
