I put everything together, and connected it to my NAS. I decided, not to check for bad blocks on the disk, but just to rebuild the arrays. If something is wrong with the disks, it will show during build. Since this is a Qnap NAS, I had to figure out how to clear the error status on all the disk. As it turns out, the error status is written to a file. By removing the lines which marked the disk as "error" I could restart the whole array build process. Rebuilding the arrays (from scratch) went without any problem. The last step was to write data to the raid arrays, which also went without any problems.
I monitored the disk for a couple of weeks, and everything is running just fine. So why 8 disks failed at the same time, not sure.
To all of you: Thank you for the help, and I also learned a lot. Thanks!!
