Hi All,
Apologies if this or a similar problem has been covered already in an existing thread. I have done some searching, and I haven't found this issue.
Symptoms on my Fluke 87:
-Unit is dead, no display, no beeping when trying to do a continuity test in the ohms position (yes, I tried pushing the speaker button to enable the beeping)
-There is a slight "chirping" that I can hear when switching modes.
-no backlight
Things Tried/Measurements taken:
-Resoldered the 9V battery connector as it looked suspect. No Improvement. Verified that 9V is present on the PCB
-Checked VDD to U4, and it's present (~3.2V, relative to VSS)
-Checked that the oscillator to U4 is running
Questions/Further Actions:
-U4 (main custom ASIC) seems suspect to me, given that it drives everything (backlight, speaker, display...) what other things can I try to rule out before assuming it is U4?
-There is a "TEST" mode for U4 referenced in the service manual. Does anyone know how to initiate this mode?
-Are there any options to purchase U4 (SPX-87) or similar equivalent IC?
Thanks in advance, Ivan
