Author Topic: Fluke 87 III continuous flashing ALL display segments  (Read 2939 times)
Offline raceone2Topic starter
« on: January 10, 2022, 03:59:05 pm »
 What causes my Fluke 87 III to continuously flash ALL display segments when turned ON to any rotary position? (ON for ~ 2 sec, OFF for ~ 0.5 sec, repeats).
« Last Edit: January 10, 2022, 04:08:49 pm by raceone2 »
Re: Fluke 87 III continuous flashing ALL display segments
« Reply #1 on: January 10, 2022, 07:34:10 pm »
Hey, I found out the battery was a poor excuse for a 9V so I replaced with a Duracel and corrected the problem. It works fine now!
Offline tooki
« Reply #2 on: January 15, 2022, 11:50:14 am »
Just check the Duracell every few months for leakage, since Duracell is just THE worst in that regard.
Online Wallace Gasiewicz
« Reply #3 on: January 16, 2022, 01:25:47 pm »
Lots of my Durahell batteries have leaked. But not the 9 V ones.
I am still watching them none the less.
« Reply #4 on: January 16, 2022, 04:37:57 pm »
The Durahells leak still, just they tend to dump that lovely caustic product into the terminal area after a few weeks, and then it migrates up into the battery holder contacts, and, if it is the clip type, it corrodes up the wires, or if it is a plate type it corrodes them nicely, and then migrates to the board.
Never had a failed 9V battery, other than the mass plate zinc oxide type, where at least one of the internal AAAA cells had not leaked out somewhat when the battery was at it's end of life voltage. The mass plate works well for that because they are wax impregnated, so contain the goo pretty well. If the corrosion has gone into the holder you need to replace with a new one, complete with wires, because they will be rotted out inside the insulation.
The following users thanked this post: Wallace Gasiewicz
