Just saved a 87 IV from the dumpster, its in a rough condition and has some issues.
besides corroded battery terminals which i cleaned, it has some electrical problems.
i cant seem to calibrate it. yes i dont have a calibrator, but i got a known good meter to roughly compare to when setting a bunch of pots to get the mV and Resistance values i need.
the calibration manual states, getting the Millivolts calibrated first, since everything DC depends on it. which i did.. several times.
after setting 50V, 500, 3000mV it still not reading 50 ... 500... 3000
when i short the inputs together, it shows -20..-50Ohms depending on how accurate i "calibrated" the mV range. but i never got it to read 0.
Temperature measurement allways shows "open". i tried with a k-type and resistive temperature probe.
in Ohms mode, i cant make it go past 3.3Meg with 5x1Meg resistors in series.
When its open leads, its very erratic. Overload and -5 Meg showing up bargraph going wild.
it never shows 0V in VDC, VAC, mVDC mVAC etc.
it take a while to settle after giving it a new voltage/resistance.
just Capacity measurement seems bang on, no complaints here.
looked on the board, nothing obvious. all resistors in the input section seem to measure fine. (1meg, 100k, 1k and such.
Anyone got an idea where to look? this kind of stuff is not my usual bench-guest in for repair.
ignore the horrible fuses, ill give it some proper bussmann as treat, once it starts behaving well.
