Hi everyone,
I am writing you because I bought one week ago a used FLUKE 87-IV, its my first fluke but i already started to regret it
, it had a blown 440ma fuse, so i replaced it, problem is that now if i touch the two probes together in Ohm reading i have negative ohm on display, minus 2-3 ohms, and it goes even under that if i let the probes together for much more time,
even in mV DC position i have negative readings from -10mvDC to -60mvDC, i understand that Autorange Multimeters haven't fixed values on screen while not measuring, but is it normal to go only on Negative DC while not measuring anything, Does it need Calibration or does it have some bad components to replace, if so i can replace them.
So I have already cleaned the pcb with IPA, already cleaned the connector sockets also, desoldered and resoldered it in place, checked the Fusible Resistor of 1Kohm in series and its value is correct,
Sending it to a Fluke service center is not really a possibility as here in Belgium there arent any,and sending it internationally will cost me more than the price that i payed for it, which is 100 euros
I will post some photos to you guys, please help me as i currently have no idea of where to look at
Also i didnt find any schematics for this multimeter, on Fluke website I only found a user manual and a calibration pdf for servicing
PS. I have brand new batteries inside
PSS I have started going crazy, I thought of the emf maybe being the problem due to old components being more vulnerable to them, and i have just wrapped the multimeter in Aluminium sheets, and twisted the two probes togheter, with no positive change whatsoever
