Hello,
I've had this meter for a while, bought 2nd hand fully working, never had any problems.
Suddenly it started beeping continuously with each position of the dial; I've read the problem could be caused by dirty sockets, so
I desoldered, soaked in alcohol and resoldered the connectors.
Now it doesn't beep anymore, but it seems that the inputs are non functional.
I can't measure a DC voltage or a resistance, if I take another meter and measure the internal resistance between com and V/Ohm I get an open circuit, but according to other posts it should be some MOhms.
I can't see broken/missing parts and the resistors seem to be Ok.
Does someone have any possible hint on what could be the problem?
TIA.
