OK, all. This is a common problem.
Just clean the main function switch and the encoder switch on the other side of the board.
Don't just spray cleaner willy nilly. A drop here and there at the function switch contacts, exercise it through it's settings, and a dry swab on the circuit board portion of the encoder switch to clear any particle residue.
End of problem.
