Hello All,
I have a Fluke 87V that is misbehaving. If the temperature is above 70 Fahrenheit, the meter starts in a second or less. By start, I mean the "F87" is displayed and the meter transitions to the proper mode. If the temperature is around 65 Fahrenheit, it takes ~5 seconds for the meter to start. If the temperature is below 60 Fahrenheit, the meter will usually not start at all. In all circumstances, after the meter has successfully started, I can turn it off for a few seconds and back on and it will run fine. If I leave the meter off for 30 seconds, it will be slow to start again (if the temperature is low). When it is running, the meter is stable and all functions appear to work fine.
I'd appreciate any thoughts on what the issue might be, or how to fix.
Thanks!
