This is in fact really strange about the meter having so many faults. Unfortunately I have no idea how this came to be. Who knows, maybe it was lightning. Who knows
This time I have remembered to probe relative to the circuit ground (2.5V ref output).
Actually, ADIN is at -2.8mV when in Vac mode and not changing at all, regardless of the range. This holds true for DC as well, which AFAIK has no problems with ranging/autoranging with the difference of ADIN being at -0.7mV in DC mode, +4mV for ohms etc.
This does not seem to differ based on shorted or open inputs.
Now about U7 - AD737J, the RMS-to-DC converter, (note that all measurements from here on are taken relative to battery (-), since that seems to be the ground of this IC). it is getting a stable 5V power supply, as it should, so that can be ruled out.
I've taken some measurements of the output(pin 6) and Cc(pin1) (not probing pin2, since it is tied directly to 2V5(reference output)) at different AC inputs on the probes, here are the results:
probes state: | Output pin state: | Cc pin state:
probes shorted | 2.5V (steady) | 1.43V (steady)
not hooked up to voltage source | 2.5V (steady) | 1.425V (steady)
18Vac | 2.225V (steady) | 1.97-2.17 (somewhat fluctuating, but by just a few mV)
32Vac | 2.1-2.5V (fluctuating) | 1.2-1.8V (fluctuating)
230Vac | 2.1-2.5V (fluctuating) | 1.2-1.28V (fluctuating)
All voltages of the output and Cc pins are measured in DC mode (with my other DMM). When measuring them (with my other DMM(stating this just to avoid confusion)) in AC mode, they all return 0V.
It seems that there is corelation between fluctuating DC voltages on the input/output and the overload condition.
Also to me it looks like there are issues before the RMS converter as well - on the CC pin - the voltage fluctuations on it seem to corelate to the output(pin6).
Honestly speaking, I'm not sure how to read what input voltages should produce what output voltages and what they would "mean", so I'm not sure if the 18Vac translating into 5V occurs here or before/after. Here is a link in case it would help:
https://www.analog.com/media/en/technical-documentation/data-sheets/AD737.pdfInput(pin2)/COMMON measure 2.511Vdc (as it should be), and the PDN is 3V (as it should be(i think, judging by the datasheet))
