Author Topic: fluke 87V Eepr error  (Read 2717 times)
Offline charlydTopic starter
« on: November 11, 2024, 09:09:55 am »
Hello today i worked on a little in between project, i have this fluke 87V on the bench which got the known Eepr err.
the board rev. is 009 and i am looking for a good working eeprom export.  can somebody support me with that.
i fixed a fluke 87V EX after clearing the board for hours(especially under the display area took me long)
but this unit has a board 010 rev. the newer version.
i could try an export from the eeprom from that unit but because it is a different board the component plan is a little different. component values are different so the export from a 87V EX will not be in calibration i guess. and maybe even to far of and so not usable.
who can help me out and export his content from the 87V. and share so i can flash mine and you have a backup for your unit. i am even willing to pay $$$  for it.
if you are willi g to help me i can support you with more info.
btw. also a  broken unit which still gives display is ok.
or if you have a broken Fluke 87V  for sale please let me know. i still need some housing parts too.
« Last Edit: November 11, 2024, 09:32:04 am by charlyd »
Offline shakalnokturn
Re: fluke 87V Eepr error
« Reply #1 on: November 11, 2024, 11:49:24 pm »
I'd give the 87V EX dump a try, whatever you find you're more than likely to need a readjustment anyway, the calibration constants are factory written for each meter.
You could try with 88V dump also if you find one, the only difference is the RMS conversion, rest of hardware should be identical.
Offline Ugur
  • Country: tr
« Reply #2 on: November 12, 2024, 01:40:13 pm »
This device has a lifetime warranty. Unless there is user error. This error is not a user error. In this case, the authorized service in your region should help.
« Reply #3 on: November 12, 2024, 08:38:14 pm »
thanks for the feedback but i have to look for a good dump then and you says the cal. contants are facto....
but aren t they overwritten during the flash?
and as for the lifetime warranty, i gues the unit may not be opened, i assume. i have searched for the warrenty but i found 1 year and not lifetime at the fluke side.
Offline Ugur
  • Country: tr
« Reply #4 on: November 13, 2024, 05:52:21 am »
It is stated on the first page of the user manual. I am sure that this device has a lifetime warranty.
« Reply #5 on: November 13, 2024, 06:29:58 pm »
i am for sure gonna try but this is what i found
Offline tooki
« Reply #6 on: November 13, 2024, 07:43:16 pm »
Those previews are irrelevant because they’re for Fluke Calibration and Fluke Biomedical, not for Fluke (no extra word) test gear. You need to look at the device manual, and others already did that for you.
No, the 88V has other features, so definitely different firmware. The 83V hardware is identical (a few passives unpopulated IIRC), but uses firmware to disable the TRMS converter.
The following users thanked this post: Ugur
Offline Ugur
  • Country: tr
« Reply #7 on: November 14, 2024, 08:39:02 am »
The warranty period for Fluke Calibration products is 1 year. Different warranty periods are given for each device
« Reply #8 on: November 17, 2024, 11:13:54 am »
Hi thanks for the feeback and Ugur with the knowledge of the 1 year warrenty am i still in the need of a firmware file export. i prefer one from the exact same board model rev. 009 so who can export a file for me for his device?
« Reply #9 on: November 18, 2024, 08:56:30 am »
@Ugur today i did a call to fluke service centre. and when no water damage(and it doesn t have) it is no user error so in warranty.
i will come back on it here. because it has board rev. 009 which is not very famous so do they swap for a new unit or repair? i hope a new with better board rev.
thanks for your advise...
« Last Edit: November 18, 2024, 08:58:30 am by charlyd »
Offline Ugur
  • Country: tr
« Reply #10 on: November 18, 2024, 02:18:15 pm »
They will most likely replace your device with a new one.
Enjoy your new device. :)
Offline tooki
« Reply #11 on: November 24, 2024, 04:55:56 pm »
Fluke handheld multimeters are not Fluke Calibration products.
The 87V has the limited lifetime warranty, not 1 year. :)
You’ll almost certainly just get a brand new meter. :D
« Reply #12 on: December 28, 2024, 09:30:53 am »
Hi indead i got a new 87V boxed from fluke after sending it in with the message , Eepr error & gsm error. (board 009).
so thanks for the advise here i wouldn t have thought about it 😉
The following users thanked this post: tooki, robert.rozee
Offline Ugur
  • Country: tr
« Reply #13 on: December 30, 2024, 05:40:58 am »
As we expected.... Some of Fluke's multimeters come with a limited lifetime warranty. Remember that.
