Hey all,
Here are some pics of the Fluke 883A Differential Voltmeter I just acquired locally for $20. Once recapped this thing is damn near spot-on to my 6 1/2 digit Keithley! I didn't even let it fully warm up.
I opened it up and replaced all the leaky electrolytics. A good number of them had this bumpy texture to them, where the electrolyte has leaked out and nearly uniformly coated the outside of each cap with a bump off-white substance. (will take a pic) They didn't damage the board much. I was able to clean most of it up with IPA. There were a few spots where it left some marks.
The purists are going to hate me as I used radial caps I had on hand rather than the perfect sized axial caps. In a few places I had to extend the leads as well because they would not reach.
I only replaced the caps that had leaked, and the main filter caps. I will go through and at least test the other ones. I may replace them too. This unit is from the early to mid 60s I believe. So they are bound to fail.
I guess I ought to try to check the carbon comp resistors as well, but I am surely not going to desolder them. Just a quick in circuit check perhaps. But given how accurate it is things seem to be working correctly.
Although this first picture makes it look backlit the meter is just being lit up from the top lighting without the cover on. I may install a backlight, though. UPDATE: The second photo with the maber glow is where I added a backlight to the meter with LEDs (see below).
I am going to put together a video on this as well. Note that W2AEW did a great video on these here:
https://www.youtube.com/watch?v=9dXlPwQkOeg
