That failure is not so common, I cannot remember to have heard/read of such a case. Maybe others know better.
I recommend to check the capacitors 1st, not to blindly replace them. My unit is from 1992, and still doing fine.
If you have the opportunity to check some of the ranges, that would reveal if it's necessary to calibrate the unit. It's very stable over decades.
If you find gross errors, then maybe there's something fishy, or a calibration attempt has failed.
Do you know something more about the pre-owner?
If that's not an expert, maybe he simply was not accustomed with the calibration process, maybe he did not unlock the calibration mode, or forgot the (changed) pass code.
In the other case, the storage memory might be defect. I don't know at the moment, if that's an EEPROM, have to investigate in schematics.
Yep, there's U505-A, a 93C66. That's probably the calibration-EEPROM.
Depending on the vintage of your unit, that might be a candidate.. In the past, I had some experience with this family, bit-flips, and fail of the internal charge pump, if I remember right.
Frank
