Hi all,
I recently purchased a fluke 8842a DMM for my bench.
After opening it up I saw that it looks like the copper is lifting off the optional boards.
I guess this is just due to It's age...
after testing all the inputs I discovered that the low VDC range seems to float after test.
If I test 5v the display reads 5v, then if I remove the probes the reading will stay at 5v and trickle down a little bit.
If I then short the probes the reading will return to 0.0v
this doesn't happen on the higher DC ranges, I can hear a relay switch over which leads me to believe there is a fault in the lower range circuit.
Luckily for me the 8842a manual has an extensive troubleshooting section, so will take some time this weekend to go through it and test.
Has anyone had an experience with this type of problem before?
Thanks for your help.
