I've got a Fluke 8846A working fine (in spec) on AC & DC volts and amps.
Ohms, continuity, diode, capacitance and temp all give false readings.
Open reading on ohms: 224ohms
Open reading on continuity: 224 ohms
Open reading on diode: 0.224V
Short on capacitance: 28.4uF
Short ohm readings seem to be OK.
With another meter connected on these ranges, all outputs are 0.224VDC. (Specs say 13V).
I don't have schematics for this meter, so I'm at a loss on what to test on the main PCA.
If anyone can provide any tips on what to test, or if you've encountered this issue before, please
send me a message. Thanks!
