If in voltage auto range and with open leads connection, the measured input voltage keeps getting more and more negative. It resets at about -200mV, probably with the first range switch (the relays click). And then begins again.
It also happens in the lowest two fixed ranges (there is no relay clicking between those two). With the higher sampling rate, it is charging faster. On Manuel it charges to over negative 1V. I did not take it apart yet. Wanted to check first if that is expected from a meter that old, or if somethings to be fixed
Schematics are attached. Any Tips?
