Author Topic: Aoyue 738 4 in 1 solder station power board  (Read 2612 times)
Offline mentholflashTopic starter
Re: Aoyue 738 4 in 1 solder station power board
« Reply #25 on: August 04, 2023, 11:27:43 am »
Hi All
I replaced the voltage regulator and it now shows 5v at the output of the regulator
but still no display
 Cheers
« Reply #26 on: August 07, 2023, 07:26:00 am »
Hi all
So i get 5v at the vcc pin and output of v regulator and at least 1 pin going to the display
What should i check next
Cheers
« Reply #27 on: August 15, 2023, 07:14:31 am »
Hi
I have remembered what i did a little more
I couldnt get the heating element out of the handle so i pulled the thermo and element with a pair of pliers then it went bang
Would this help to narrow my problem
Cheers
I have also been away for a couple of days to the city
I bought 2 bt137f 600 would i be able to swap these out with the bt137 600e
Thanks
« Last Edit: August 15, 2023, 07:17:59 am by mentholflash »
Online wraper
  • Country: lv
« Reply #28 on: August 15, 2023, 09:30:58 am »
Hi
Cheers
Thanks
Do you mean you were removing it while station was connected to the mains voltage? If that's the case, you likely destroyed low voltage electronics by applying mains voltage onto thermocouple. And that was the reason why 7805 died, likely together with MCU and other ICs.
