Author Topic: Fluke 89 IV repair - help needed  (Read 1511 times)
Offline petermifTopic starter
  • Country: mt
« on: January 19, 2020, 05:55:01 pm »
Hi guys,
My first post :)
My Fluke 89 had been in storage while I moved home and its batteries leaked out some electrolyte. When i opened it up the leakage seems limited to the battery compartment only so i thought i was lucky but once i cleaned it and put in new batteries it powers up ok by reads negative ohms!!
Inside it looks new but I'm wondering about[/img] the yellow component with the slot in it (see picture) and also any ideas about fixing the negative ohms reading.
Any help / advice is greatly appreciated.
Thanks,
Petermif
Offline joeqsmith
Re: Fluke 89 IV repair - help needed
« Reply #1 on: January 19, 2020, 06:27:09 pm »
Slotted part is a spark gap,  battery looking part is the super cap,  other is a resistor.
Is it a problem in all ranges?  Do all of the other modes work, assuming you have a way to check them?
  • Country: mt
« Reply #2 on: January 19, 2020, 07:11:49 pm »
Hi Joe,
Thank for your reply. Yes the error is on all ranges of ohms but also on V and mV etc however i noticed that with the leads unplugged the meter reads OL on all ranges whereas with the leads connected and shorted i get a negative 30 ohms reading on all ranges but on the kohm range its -2.87k !! Also with the leads still shorted i get -2.7mVDC, -0.1344 VDC!!! Weird behaviour indeed!
Is there a way to reset the meter or  some other method to fix this?
Thanks
Offline andy3055
« Reply #3 on: January 19, 2020, 07:52:59 pm »
You can download the service manual from below link and check the calibration procedure:
https://elektrotanya.com/fluke_87-89_iv.pdf/download.html#dl
Offline shakalnokturn
« Reply #4 on: January 19, 2020, 08:43:28 pm »
There isn't much point in going through any calibration before you're sure it has been cleaned of any electrolyte.
Once correctly cleaned I doubt it will need calibrating at all.
If it were mine I'd be making sure that the supercap is discharged or removed, remove shields, LCD, switches and wash the lot down.
As an example the DMM in this gallery https://photos.app.goo.gl/uCUmZvgM6NLxzHAJ7 was in quite the same case as yours, after several good toothbrush scrubbings in water, soap, vinegar, much rinsing, and a final scrub with WD40, this meter was back within tolerances.
« Last Edit: January 19, 2020, 11:24:45 pm by shakalnokturn »
Offline retiredcaps
« Reply #5 on: January 19, 2020, 09:01:12 pm »
I agree. Don't touch any calibration.
If there was battery leakage, clean the entire PCB first with IPA and gently scrub with a clean toothbrush.
Let it dry thoroughly overnight or use a PC fan to blow on it.
PS. There are many threads here on the forum where a simple IPA cleaning fixes negative ohms.  There was either battery leakage or dirt/debris on the pcb.  The dirt/debris may have entered when the user was changing the battery or fuse or the meter was just used in a dirty and dusty environment.
Offline retiredcaps
« Reply #6 on: January 19, 2020, 09:12:27 pm »
Try eneloops instead of akaline next time if you forget to take out the batteries before long term storage.
Offline z01z
« Reply #7 on: January 21, 2020, 06:48:35 am »
You mean the PCB? I'm not sure that's a good idea.
« Reply #8 on: January 21, 2020, 08:17:57 am »
Yes the PCB. I wasn't convinced it was a good idea either before trying, after repeated cleaning with the usual methods I still had the mV range above zero. The WD40 got that sorted.
What harm are you expecting it could cause?
