Author Topic: FLUKE 89 IV true rms multimeter powers, measures nothing  (Read 3927 times)
Offline vicusa99Topic starter
« on: October 15, 2018, 10:06:55 pm »
Last time it was successfully used, until i battery contact was broke by mistake
Need to repair the battery contact that WAS BROKEN, SO NOT HAVING NEW REPLACEMENT I SOLDER DIRECT A WIRED TO THE MULTI. PCB battery contacts + -
I test  to measure some resistance or voltage
But it shows 0.00 ohm, or 0 volts it beeps when switching to beep mode. It should read OL, before start.
Switching to voltage gives 0.00.
Thought at times, it might rush around displaying any number, both it resistance and voltage mode. But for the most 0.00 and it does not matter what the test leads do. Open, connected to something or shorted.
Fuses are checked, batteries changed. Still the same.
So it seems like something in the input stage might have a break / gap.
Anyone have any idea of which component to investigate more or try to change??
Online coromonadalix
Re: FLUKE 89 IV true rms multimeter powers, measures nothing
« Reply #1 on: October 15, 2018, 10:34:51 pm »
Are you sure the dial is in the right position  ?
I had dismantled my meters to change the super caps, i mistakenly turned the dial one position, once re-assembled it did not work okay ?
You can find an complete battery connectors kits on Ebay  (the 5 parts kit)  59$ usd plus shipping ?  and after a few weeks some new kits re-appears ?
https://www.ebay.com/itm/FLUKE-87-4-89-4-187-189-789-MultiMeter-Battery-Contact-Kit-OEM-NEW/253325696665
« Reply #2 on: October 15, 2018, 11:34:40 pm »
I can turn the dial differents position...
Can you explain more.
Yes i saw the conectors on ebay but quite expensive. Thanks any ways.
If make read imput , itest some of the resistor and are reading ok.
My concern is multimeter is not show input values only 0
Screen and everything work.
Offline The Soulman
  • The sky is the limit!
« Reply #3 on: October 15, 2018, 11:57:42 pm »
Turn the dial 180 degrees and reassemble. (the contacts on both ends of the dial are probably slightly different)
Offline retiredcaps
« Reply #4 on: October 16, 2018, 12:24:22 am »
Show us a picture with the rotary dial set to ohms and the lcd screen readout.  Do the same for DCV and have the probes measuring a 1.5AA cell.
« Reply #5 on: October 16, 2018, 05:46:52 pm »
Hi here some pics
first 3 are the Resistance without measuring or not a Resistance + foto #3 continuity doesn't either read
last 3 pics are dc of a battery same behavior.
Many thanks for moving more tips.
Offline retiredcaps
« Reply #6 on: October 16, 2018, 07:13:54 pm »
Assuming the rotary dial is setup correctly, here are some suggestions.
1. check the input protection components "in circuit"
a) fusible resistor should measure 1k ohm
http://mrmodemhead.com/blog/fluke-87-fusible-resistor/
b) PTC should measure around 1.1k ohm
c) MOVs and spark gap should all measure 0L ohms
2. If the battery contact was broken due to alkaline battery leakage, it would be a good idea to carefully inspect the entire pcb.  An IPA bath might help if you see any alkaline leakage.
Offline ElecSeb
« Reply #7 on: October 22, 2018, 11:20:09 am »
Wiresfluke89IV-3.jpg -> is that yellow/orange element cracked? (not quite visible on your picture)
Offline Samogon
« Reply #8 on: October 22, 2018, 03:38:50 pm »
It is slit, so called spark gap
The following users thanked this post: ElecSeb
Offline Samogon
« Reply #9 on: October 22, 2018, 03:52:07 pm »
Vicusa99,
I think that ADC is kaput, i have spare mainboard to get IC from it, but looking at battery contacts being destroyed i see big expense here.
Ebay seller ~$50 for contacts set
Shipment and IC donor, not even counting labor
Offline Robomeds
« Reply #10 on: October 23, 2018, 04:16:39 am »
Are you sure the switch has all it's contacts?  I didn't notice a missing contact with mine until it didn't work correctly.  The problem seemed to be the meter didn't understand what it was supposed to do because only some of the connections made by the dial were actually being switched.  Check out my thread on it. https://www.eevblog.com/forum/repair/fluke-187-switch-contacts/msg1093086/#msg1093086
You might have the same issue.
« Reply #11 on: November 05, 2018, 03:26:40 pm »
inner knob switch contact are missing. 2 of 4. i thinks that is maybe the problem, the issue would be the contacts, i didnt noticed until watching other pics from another unit on your site. where i cant found them_, Ebay doesnt have .also the external know is broke.
Offline lowimpedance
  • Watts in an ohm?
« Reply #12 on: November 05, 2018, 10:59:11 pm »
Both contacts missing !!. As this meter was apparently working before the battery wire mod , did you have the switch rotor assembly out at any time during that mod ?. If so the contacts clearly have fallen out.
Have you had a very good look around the area where you have been working on this meter ?. Otherwise replacement contacts will most likely have to be from a donor Fluke with similar contacts. Not sure you would have much joy contacting Fluke directly, (give it a try though).
« Last Edit: November 05, 2018, 11:37:04 pm by lowimpedance »
« Reply #13 on: November 05, 2018, 11:09:33 pm »
You miss clearly 2 contacts, the dial has 4 contacts,  fluke usa has the battery contacts, not the dial contacts  (tried to order them - no longer available), i ordered all the clips from them 1 1/2 month ago
pn 89-4-8006  is the small lenght battery clip
pn 89-4-8012  are the 3 dual battery  clips
pn 89-4-8003   is the longest battery clip
You will end around 60$ usd for the complete clips kit
An used working Fluke 187-189 / 87IV-89IV  meter is easily 125$ usd or more ? , before you buy you must have a photo of the contacts, many used meters have them corroded ...
« Last Edit: November 06, 2018, 04:02:10 am by coromonadalix »
Offline Robomeds
« Reply #14 on: November 08, 2018, 04:10:54 am »
As I mentioned in my thread on almost the same issue, I contacted some of the ebay sellers and was able to get a contact.  Per my other thread it was Ebay seller Fluke-USA that had one.  I had to just contact them through the messaging system.  It wasn't on their ebay store.
Offline Robomeds
« Reply #15 on: November 08, 2018, 04:18:56 am »
No idea who this seller is (I found it via an image search) but those 87-5 contacts look like they may be the same parts as the 89-4.  That said, I don't think those are actually 87-5 contacts.  Other 87-5 pictures don't show the same contacts nor do they have the back wiper.
https://pakmuhandes.com/fluke_test_mearument_equipments)/fluke_accessories?product_id=621
Yup... 87-3.  Check out this thread
https://www.eevblog.com/forum/buysellwanted/wtb-(ukeu)-rotary-switch-contacts-for-fluke-87-iii/
« Reply #16 on: November 08, 2018, 10:25:06 am »
Tried to source the dial contacts,  many fakes websites china related ..........  be careful   you'll get some deceptions,  never had any emails answers after lots of trials
My solution was to buy used / defective meters to source them.
