Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Fluke 8920a Voltmeter Repair Need Help
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Fluke 8920a Voltmeter Repair Need Help (Read 963 times)
daisizhou
Frequent Contributor
Country:
on:
May 28, 2023, 10:35:38 pm »
Hello everyone,My fluke8920a voltmeter has been under repair,It's malfunctioning very strangely,I tested it for a long time,it's still faulty now.
Below I will describe its failure phenomenon,After power on,Press the "LO RANGE ENABLE" button,The analog pointer keeps swinging back and forth,I don't know what's broken.
I try to plug in a 50 ohm load,And press the "LO RANGE ENABLE" button again,The malfunction is still the same.
In order to explain the fault more clearly, I took a video,Please let me know if you know or you have the same glitch, thanks
https://youtu.be/l_2e7JcHB2g
repair manual-->
https://www.elso.sk/media/download/pdf/fluke/man/Fluke_8920A_8921A_Manual.pdf
Last Edit: May 28, 2023, 10:39:59 pm by daisizhou
Logged
daisizhou#sina.com #=@
daisizhou
Country:
Re: Fluke 8920a Voltmeter Repair Need Help
Reply #1 on:
May 29, 2023, 03:05:25 am »
S202 switch
Logged
coromonadalix
Super Contributor
Country:
Reply #2 on:
May 29, 2023, 02:32:35 pm »
check the logic going into U205, it may have been damaged
Logged
daisizhou
Country:
Reply #3 on:
May 29, 2023, 08:22:03 pm »
thank you for your reply。I checked U205 it is working,Sometimes press "LO RANGE ENABLE" it is normal, sometimes it is faulty
I wiped the motherboard with ethanol and baked it, the fault disappeared for a while, but the fault reappeared after a while
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
