As one's splendid "sub-ppm" levels calibration/hobby lab goes, once you think you've figured your 8 1/2 digit measurement on your calibrator calibration, your ACV differential meter poops out.
My 931Bs "fourth digit" doesn't want to adjust smoothly and I suspect R37 is not tracking well. It's a hermetic pot. I wonder if anyone has run into similar issues and figured out a solution. Other than getting a replacement - and I assume throwing out its cal/adjustment - I can only think of poking a hole and spraying some Deoxit in there (it's a ww, so no reason for FaderLube), and letting it dry. Then working it and hope it's smooth like a baby's buzzum.
The other issue is the mechanical dial is not quite going from 00 to 100... And yes, I absolutely want to keep the calibration untouched!
How would you tackle this?
