Author Topic: SHARP S202T02 Replacement  (Read 569 times)
Offline zero0dTopic starter
  • Country: hr
« on: October 01, 2021, 08:43:41 pm »
Hi all,
i'm searching for the replacement part for SHARP S202T02 (SHARP S202T02F)
https://www.digikey.com/en/products/filter/solid-state-relays/183?s=N4IgTCBcDaIMpgAxgCrJAXQDQgKxVAAcoBGHQ4yExRAX1qA
i don't have experience with this kind of parts, is this a drop in replacement maybe:
https://www.digikey.com/en/products/detail/ixys-integrated-circuits-division/CPC1976Y/1277138
Br.
Online wraper
  • Country: lv
Re: SHARP S202T02 Replacement
« Reply #1 on: October 01, 2021, 09:00:34 pm »
It will work fine as replacement unless it needs to be mounted on a heatsink. Just keep in mind their pinout is exactly the same but pin order is reversed, so will face the opposite side with it's marking.
The following users thanked this post: zero0d
