Hi all,
Inspired by the forum i picked up a fluke 99 which has problems powering up.
i attempted to turn it on, but alas, all is did was squeak at me.
so, its come apart. I have looked at the and found much the same.
obviously with more buttons.
so without further ado, here are some photos and there i think the fault is. but as to why, thats where your help comes in.
First up the unit itself. generally looking in good condition no major marks or scratches - rubber already removed
as with the fluke in the video by dave, it opens up like a beautiful electronic book with parts nicely laid out. (EDIT) just spotted the large caps hashed on the top of the scope probes
here is a close up of the screen and keyboard side. I am condident the keyboard is working as when powering up is attempted it does squeek as i said. going to leave that for now
This is the back of the board with the BNC and bannana connectors at the top. not looking too bad... at first glance
with it being a power issue i had a closer look at the DC input, nothing obviously at fault here
front side again and there is a small dent in the cap but nothing serious though the 'sheild' to the right does look like its gotten hot. ..... better look on the other side
ahh, well that'll be making soimething unhappy for sure. question is, has it blown the track out, and which componants has it taken with it. infact, which componant failed to start with.
so now i have an area to look at my plan is to have a look at the service manual and see if i can glean anything from it, but if you can save me time and throw some ideas arround i'd be very happy to hear them.
as a bit of background I generally work with cars so this tank of a thing is ideal, very little i work with is ideal for the task. checking crank signal patterns or ensuring the ECU is firing injectors as expected.
We have a Fluke 123 at work, but it doesnt have cursors (a right faff) and i have also got a THS710a but still getting to grips with that.
