Hi. I have a new LG SK10Y soundbar.
In my excitement to test it out I forgot to check the input requirements on the sticker. I plugged it into 220v and, there was no spark, no strange sounds, no smoke and no smell. I pressed the power button, and there was a confirmatory beep, but nothing else happened.
Realization quickly dawned and I switched it to a 110v source. Same symptoms: pressing power button results in confirmatory beep, but nothing else (there should be lights and stuff). Also, it doesn't respond to power on signal from the included remote.
So it seems that the control panel is fine with whatever voltage was getting to it, but nothing else was...
My (limited) experience in these scenarios tells me that usually it is just the power board (or the power-related part of the board) that tends to fail. So I disassembled the unit and it does have a separate power board. However, after inspecting the board as well as I could (which is not saying much), I didn't notice anything obviously burnt or damaged. The board even has a fuse but I tested it for continuity and it is fine.
I'm actually more concerned by the fact that I didn't notice anything burned, that the fuse is fine, and that the power button still gives me a beep. That makes me think that perhaps the power board itself had no problem with the 220v input, and then passed on a stepped-down voltage that was too high and then fried something farther down the chain of circuit boards (but not the control board with the power button which still beeps). That scenario would make this repair a lot more costly and complex, I think.
After posting this I'm going to edit this from my phone to add pictures, so if you don't see any pics just hold tight for a few minutes and check again, thanks.
Edit: had some trouble getting the pictures uploaded because of the strict size requirements here, and inability to edit easily on my phone. Two pictures now available of top and bottom of board. More detailed pictures available upon request.
The power board seems to have a rather straightforward, simple design. I think my first task would be to test to see if this board is outputting the expected voltages from a 110v input. You can see the input connector with fuse on one end, several capacitors and a transformer in the middle, and then a connector cable at the opposite end which connects to the next board in the chain.
