Author Topic: SMD component identification  (Read 2198 times)
Offline ElectricGuyTopic starter
  • Country: pt
« on: February 02, 2016, 03:12:29 pm »
Hi;
Can somebody help me confirm that the component on the red circle of the image is a SN74LVC1G3157.
The component is marked 3157 and is placed in a TFT display board.
IT gets really hot, over 160º measured with a "special edition" Flir E4, and if i freeze it with freeze spray the display board works.
Also, is the package SC-70?
Thank you.
Thank you!
Regards
ElectricGuy
Offline pmichel
Re: SMD component identification
« Reply #1 on: February 03, 2016, 12:40:57 am »
The part might be SGM3157 (datasheet shows 3157 as the marking instead of C5 on the other P/N), but comparing the two datasheets they look similar enough to probably be interchangeable.
http://en.sg-micro.com/index.php?m=default.products_show&id=188
« Last Edit: February 03, 2016, 12:47:01 am by pmichel »
Offline pmichel
« Reply #2 on: February 03, 2016, 12:44:36 am »
That would also match the SC-70 package too.
  • Country: pt
« Reply #3 on: February 03, 2016, 11:08:42 am »
Thanks
Thank you!
Regards
ElectricGuy
Offline PA0PBZ
« Reply #4 on: February 03, 2016, 11:47:36 am »
So probably the part is not broken but heavily overloaded?
  • Country: pt
« Reply #5 on: February 13, 2016, 11:19:35 pm »
Just an uptdate.!
Changed the part and it works great now!
Thank you!
Regards
ElectricGuy
