Great topic ! Love these scopes, thanks all for the information
Shakal, have a (Philips branded) 3394A too, though yours is much more recent, FW is over a year and half younger than mine.
Also have a 3384B (Fluke branded).
I love these "hybrid" scopes, great general purpose scopes that work fine for 99% of the stuff.My fancier digital scope don't need to be fired up that often. The combiscope is quieter, less power hungry, starts faster, and has that analog capability when you want it.
I used to use a Tek 2232 but it didn't like the house move and has developed an issue with the focus.. the control now only let's me choose between a trace/readout of thickness between 5 to 10mm !
Not very usable... will get round to fixing the 2232 of course, but too busy working on the house. So in the meantime I switched to using the Combiscope. I can then compare the 2, and appreciate the good in each of them.
Generally speaking I prefer the Fluke / Combiscope because it's 5 years younger in design, and it shows. Less " temperamental ", more sophisticated features and user interface, a bit more memory.. and 4 channels instead of two.
The 2232 however wins (for me at least), in the user interface department. I find the controls and menus so much more intuitive to use. It's a breeze. The Combiscope here and there, is a pain. Some menus baffle me and I have to think 10 times to figure out what button or knob to use, and in what direction to turn it, in order to get the desired result. Also, as has been already mentioned, and I agree 100%... the acceleration of the rotary knobs leaves a lot to be desired. Either too slow or too fast, no middle ground. Drives me a bit nuts and wastes time.
Also too many push buttons.. I keep having to stick my nose on the front panel to read all the button labels to find the button I want. My brain just can't build a "map" of what button does what. Again waste of time.
Also, the sampling rate on the combiscope is not great. It's even lower than the 2232 even though it's years more modern. 250MS/s for the 2232, on each channel, and only 200MSps for the Fluke and I fear it's multiplexed ?! So since it's a 4 channel scope, that means possibly only 50MSps per channel vs 250 for the Tek. I have a copy of the original paper manual for the Combiscope, and could not find clear information stating whether or not the 200MS were shared / multiplexed.
But other than sometimes questionable user interface decisions, overall the Combiscope is my favorite. Also, big advantage of course is the combiscope offers automatic measurements, and math functions. 2232 does not.
Both my A and my B have the FFT / Math package it appears.
As for the differences between the A and the B : I stacked them on top of one another, fed them with the same signal, and then entered each and every menu and sub-menu, to hunt for differences. Could hardly find any.. same exact menu items everywhere, same memory depth, same everything. Only difference I found are :
- The 3394A (200MHz) has a 50ohms option which the 3384B (100MHz) does not.
- The 'B' has a lot more driver options for plotters and printers.
So I use the older 'A' scope because of its 200MHz B/W and 50ohms option, but at some point I will want to use the plotter and printer output, as I would love that to document my work. I am tired of taking crappy pictures of the screen with my camera. It never looks nice.
Since I understand from above comments that the A is not compatible with the B F/W... I am out of luck.... unless your 'A' which has a much more recent F/W than mine... would happen to have the plethora of printer drivers that my B does. I could reflash my scope with your F/W !
As for calibration needing to be done regularly... I notice that my scope takes care of that himself : it interrupts me regularly to run a calibration whether I like it or not !
As for batteries, RTC is still holding up after 27 years !
So good batteries they must be ! I guess I should none the less open the scopes to make sure they are not starting to leak...
I have to say I got lucky and both my scopes somehow were working 100% fine, so I didn't need to open them up ! Don't even know what they look like inside, shame on me !
I am used to old Tek scopes, but I have no idea about the guts of these Combiscopes...
@HighVoltage : might it possible that you send me a copy of the computer S/W for these scopes ? That would allow me to take care of them... and let ShakalNokturn read his F/W, so he can send it to me and then I can reflash my scope to get the extra printer drivers ! That would be awsome
Anyway, was great to see a topîc on these scopes, I have grown quite fond of them, might buy some more of them if I ever come across cheap broken ones. A 3394B would be good.
