Author Topic: Fluke PM-6304 Programmable Automatic RCL Meter - bad display  (Read 2828 times)
Offline RutgerTopic starter
« on: November 26, 2015, 03:51:15 pm »
The display on my Fluke PM-6304 isn't working, any tips on how to fix this?
Offline HighVoltage
Re: Fluke PM-6304 Programmable Automatic RCL Meter - bad display
« Reply #1 on: November 26, 2015, 05:39:13 pm »
Did the display just stopped working?
Can you be more specific?
I only have the PM6303A and the PM6306
May be you can open the unit and take some pictures
Here is a picture of the inside of the PM6306
May be you are lucky and it is a loose connection of the ribbon cable to the display, as I had it once on a PM6303A
Offline Shock
« Reply #2 on: November 26, 2015, 11:45:24 pm »
Are you experienced in repairing? Have a multimeter and a oscilloscope?
I'd start by removing power from it then reseating the cables.
https://doc.xdevs.com/doc/PHILIPS/PM6304/PM6304_Service_manual.pdf
