Hello,
has somebody downloaded firmware (EPROM dump 27C1001 - OTP) for serial interface card RS232 (label on my eprom is PM9549 v 2.2 / or similar version)?
I have unit that can not receive command, sending is OK. I have tested all possible, now I need to check FW.
I can upload main firmware (from the main board) v. 1.8 (EPROM 27C512) if somebody needs this.
Thank you !
